Texas Instruments TI-84 Plus Calculator Logo
Posted on Feb 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello! My TI-84's multiplication, division, addition, and subtraction button act as the clear button among other button errors. Any help please?! thank you!
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Feb 07, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4673438
Points
21595
Did it start doing it on its own? Or did this condition appear after you played some third-party game? If the last case is the correct one then the game may have reconfigured the keypad.
  1. Try to exit the game from inside the game.
  2. Remove the game from the Ram.
  3. Press [2nd][MEM][2: Mem Mgmt/Del][1:All]
  4. Use the down arrow to scroll along the list of objects in memory.
  5. Find the offending program.
  6. Use down arrow to point to the program and press [DEL].
If the program has an asterisk to the right of its name, it is archived. If you press DEL you will be asked if you want to delere it. Enter the number to the right of Yes and press [ENTER].
You may have to wait for the calculator to defragment the RAM.
  • k24674 Feb 09, 2010
    OOPS The sentence
    "If the program has an asterisk to the right of its name, it is archived."
    should read
    "If the program has an asterisk to the left of its name, it is archived."
1helpful
What is factoring and give the examples
Quick-Start Guide When you enter an expression into the calculator, the calculator will simplify the expression by expanding multiplication and combining like terms. At this point the calculator will attempt to factor the expression by dividing a G C F, and identifying a difference between two squares, or factorable trinomials. Use the following rules to enter expressions into the calculator. Variables Any lowercase letter may be used as a variable. Exponents Exponents are supported on variables using the ^ (caret) symbol. For example, to express x 2, enter x ^ 2. Note: exponents must be positive integers, no negatives, decimals, or variables. Exponents may not currently be placed on numbers, brackets, or parentheses. Parentheses and Brackets Parentheses ( ) and brackets [ ] may be used to group terms as in a standard expression. Multiplication, Addition, and Subtraction For addition and subtraction, use the standard + and - symbols respectively. For multiplication, use the * symbol. A * symbol is optional when multiplying a number by a variable. For instance: 2 * x can also be entered as 2x. Similarly, 2 * ( x + 5 ) can also be entered as 2 ( x + 5 ) ; 2 x * ( 5 ) can be entered as 2 x ( 5 ). The * is also optional when multiplying parentheses, example: ( x + 1 ) ( x - 1 ). Order of Operations The calculator follows the standard order of operations taught by most algebra books - Parentheses, Exponents, Multiplication and Division, Addition and Subtraction. The only exception is that division is not currently supported; attempts to use the / symbol will result in an error. Division, Square Root, Radi cals, Fractions Division, square root, radi cals, and fractions are not supported at this time. A future release will add this functionality.
that's all I can say basically I learned it this way.
1helpful
What does product mean in maths
When you perform an arithmetic operation such as addition, subtraction, multiplication, or division the result has a specific name. The result of addition is called the sum; the result of a subtraction is called the difference; the result of multiplication is the PRODUCT. Finally the result of a division is the quotient.
2answers
What does poduct mean in maths
Sample of how to create a python program that will input two numbers and will ask the user of operation to perform as to addition,subtraction,multiplication or division the program should perform the...
Assuming that the input numbers are given by the user:print "Menu"print "1. Addition"print "2. Subtraction"print "3. Multiplication"print "4. Division"print "0. Quit"
a = input("Please make a selection:")if a == 1: x = input("Please enter a number:") y = input("Please enter another number:") answer = x + yprint "%r plus %r = %r" % (x,y,answer)elif a == 2: x = input("Please enter a number:") y = input("Please enter another number:") answer = x - yprint "%r minus %r = %r" % (x,y,answer)
The same goes for everything else just with different signs. Don't forget that "*" is multiplication and "/" is division. Also, for 0. Just use:
elif a == 0: quit
1helpful
Is there a guide of how to use this calculator i do not under stand how to work this
Here's a link to a pdf of the manual. The basics are that you have 12 white keys near the bottom, which include the 10 digits, a decimal, and the negative sign. On the right, you have the four operating keys, division, multiplication, subtraction, and addition. You also have the Enter key which will solve the expression. You'll notice that the buttons have blue and green lettering above them, and those are for the 2nd and alphabet functions. So if you press the 2nd key on the top-left, then the on key in the bottom left, then it'll turn it off, because it also functions as the off key. The Alpha key is used to input letters which are in green above each number. Good luck!
4helpful
240/20x6-13+41 can't figure out the answer
You'll need to use the Order of Operations to solve this problem. They are Parenthesis, Exponents, Multiplication, Division, Addition, Subtraction (Please Excuse My Dear Aunt Sally). Multiplication/Division have the same weight, so you read it from left to right. Same with Addition/subtraction.
For this problem, you see there are no parenthesis or exponents, so you move right to multiplication/division. Reading from left to right, the first thing you see is 240/20. Evaluating that comes out to 12. Now you have 12*6 (assuming the x is a multiplication symbol), which evaluates to 72. 72-13=59, and 59+41=100.
Written another way:
240/20*6-13+41
12*6-13+41
72-13+41
59+41
100
My TI-84 keys are not all working; multiplication and division show up as asterisc and clear does not clear. I have just changed all batteries, including small round one and no change
it could be that the old battery leaked inside and cause this problem in most cases this is the problem.
if you want to fix the Calculator let me know
[email protected]
Jack
2helpful
Negative exponents? .825/(10^(-3)) ? Not sure how to get it to do the negative exponent.
You entered it correctly. Although you can leave out the parentheses if you want. The calculator will do exponents before it does multiplication or division just like it does multiplication and division before it does addition and subtraction. It has a built in order for hierarchy of operations. You only need to use parentheses if you want to do something that is different from this order. FYI, dividing by a negative exponent is the same as multiplying by a positive exponent. You could enter it in either way. .825/10^-3 = .825*10^3 = 825. I hope this helps you out.
Computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
