close captioning on a tv is usually only available for use when the antenna inputs are being used. it has no way to process a cc from an auxiliary source. you should have the capability of cc with a menu item in the cable or satellite box and with the subtitle command in your dvd. good luck
More info would be good. Do you need codes to use the original pioneer remote to control another componant, or do you need codes for another remote to control the pioneer?
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual: http://www.directtv-advisor.com/support-...
