After a battery replacement the screen contrast may become too dark or too light. I suspect that in your case the screen is too light. To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] until screen darkens enough.
Make sure batteries are inserted correctly (one never knows).
Here are some steps to perform in the order they are presented. Please
read the post till the end.
A
B. Remove one of the AAA batteries.
Press and hold the [CLEAR] key.
While holding [CLEAR], reinsert the AAA battery and then
turn the calculator on.
The calculator should display the message "RAM Cleared".
Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
To adjust contrast Remove batteries including the backup battery for 5minutes.
After the 5 minute period, reinsert all of the batteries and
Adjust the contrast if necessary.
Press and HOLD the UpArrow to darken screen or downArrow to lighten it.
C.
This step requires the reinstallation of the system. So
to use it you must download the TIConnect 1.6 software from
education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
If the message "Error! Press any key to turn unit off. Then turn unit back on."Remove one of the AAA batteries.
Press and hold the [DEL] key.
While holding [DEL], reinsert the AAA battery and then
The calculator should display "Waiting...Please install calculator software now".
Connect the TI Connectivity cable between the computer and the calculator.
Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
Follow the on-screen directions to reinstall the calculator's OS.
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculatorSerial Black cable that used to ship with the TI 83
Plus. It connects to a serial port on a computer and to the I/O port on
the calculator. It requires the Graph Link software available on the TI
web site (Downloads, Software and Apps, Connectivity)USB Silver Link cable. It connects a USB port on the
computer to the the I/O port on the calculator. It requires the TI
connectivity software, also available on the TI Web site.A USB mini A to mini B cable to connect two units.
An I/O cable to connect two calculators through their I/O ports.
If that helped you (or anybody else) why is it rated two thumbs up? Does it cost you that much to rate in a coherent manner?
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Now just in case this calculator wasn't posted correctly. Here's my instructions for a Ti 83 that won't turn on. This is not the same procedure that the Ti 83 Plus has.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. And of course if the calculator does not turn on, I re-do the procedure and, increase the amount of time by 5 minutes to ten minutes that all the batteries are removed.
