Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Using the B and D buttons to set the hands of the watch to the correct time will not work. The clock is designed to *automatically* move the hands to the time that is set in the 'Home' screen, the one where you set the time and DST mode. It is important to first set both the current time and the correct DST mode before going to the HSET mode (clicking the C button or 'mode' button 6 times from the 'home' screen). Once in the HSET mode, hold the A button down until the digital numbers begin to blink. When you lift your finger from the A button, the hands may automatically begin to move. Don't worry, they will stop. Once they do, use the B (counterclockwise) or D (clockwise) button to set the both the hour and minute hands at 12.00 noon.. Then hit the A button once time. This time, when you release, the hands will autoatically move to the time that you have already set in the Home screen.
You can obtain a copy of the manual from the Casio site. Go to "Casio.com", select "support" and then "manuals", then "watches"; after which you must accept their terms and conditions. Now insert the number off the back of your watch and download your instructions.
