Maytag Neptune MAH6700A Front Load Washer Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore Elite Oasis He washer. The washer had a flashing error code Sd or 5d during the spin cycle. Sometimes it showed uL in the rinse/spin cycle. What do they mean?
  • Anonymous Mar 30, 2014
    UL error comes up part way trough cycle
Anonymous
Level 3:
  • Master 572 Answers
  • Posted on Feb 06, 2010
Anonymous
Master
Level 3:
Answers
572
Questions
0
Helped
134391
Points
1612
Sd is suds error. add only HE soap. UL is unbalanced load. watch load size and balancing loads.
What does it mean when SD is showing on the display
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
1helpful
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
I have an kenmore elite =sm9711174. the spin cycle does not always start. i have to manually spin a couple times then it starts, but now does not spin fast. only slow. do i need a new belt?
this washer does not have a belt. The motor is a direct drive. it should give you a error code at time if it is unable to spin. some codes are F-51, F-dl, and UL. from the sounds of it the main board may need to be replaced part#W10189966.
21helpful
2answers
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
7helpful
2answers
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
1helpful
4answers
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
1helpful
Not rinsing 5d code appears oasis washer
It is likely Sd.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
