How do I put my Frigidaire affinity ATF6000fs washer on clean mode...I can not find my manual..Please Help
First, you put some bleach or tide washing machine cleaner inside. Then you make sure the washer is on and hold the spin speed button and the options button down at the same time for 10 seconds. You will see "Cln" appear on the display screen. Hit start and you are golden.
When i hit the buttons no CLN appears :(
I did that and it did not work!
If you hold it down 1st time it may display a time "45" then hold them down a second time and you will see "CLN"
It depends on the year it was made/model. I have an affinity front loader and to get the clean cycle started you to have to put it on the “rinse & spin” cycle and then select “clean washer” button on the options panel (it will light up green next to the button).
Then hit start.
You need to hold the buttons for at least 10 sec for Cln option to show on the display
My manaul says to add 1/2 cup of bleach to the detergent compartment and then fill the bleach compartment to the max fill line and then do a normal cycle without clothes. it says to do this once a month. it also recommends leaving the detergent door pulled out when not in use, and leave the door open when not in use.... b/c as i'm sure you've smelled- it mildews super fast.... for really gross mildew problems it says you can use up to 3 cups of bleach.
Thank you for sharing! It worked!!!
For my model Frigidaire front load washer . Select Hand wash. Press "clean" under options (screen will appear "system clean") press start. The system clean countdown will begin.
I have a AFT7000 series and I have not been able to put it into the clean cycle. I’ve tried holding down the spin speeds and options buttons, I’ve done the factory reset and I’ve tried turning the dial to different settings and holding the buttons but still can’t get the clean cycle to appear. Any other options that I can use?
Try contacting Electrolux 1-800-944-9044 Mon- Fri 8:30 AM - 8 PM (Covid-19 could have an impact on their availability) or do a Google Search using your "(Your Product Brand Name, Model Number and Serial Number) along with these terms: "How To perform inside routine cleaning preventative and or inside cleaning aggressive Care and Clean Instructions All about the Use & Care of your washer Owners Manual" hopefully you'll be able to find either the manual or more detailed instructions for your particular model. Good Luck
Thank you for sharing! It did work!!!
Hello Tracy, thank you for your post!
From what you have described you need help putting your Frigidaire washer into a clean cycle. In order to further assist you I would need your model number. You can locate your serial tag (which lists your model number) on the door frame of your washer. With that information I would be happy to further assist you. -Matt
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Hey friend, I appreciate your for the post!
I understand you are trying to disassemble your Frigidaire washer, ATF6000FS. I have researched your error code "E90" and that seems to be an issue with your main control board or user interface board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
