And please never put olive oil on a watch as suggested by Roger R. It is too thick and in time goes rancid and gummy because it is plant based. His post is deleted as it contains bad information as well as phone numbers.
Stand on one foot, while patting you head and rubbing your stomach... AND THEN... hold the lock/unlock button until the screen changes....the press the start/stop button which should get the seconds blinking so now you can begin to change things, switch to min/hr etc by pressing start/stop again. The orange run/rest button actually does the changing. good luck!
Hi I am a watchmaker and this is a common problem that i have found a lot of times. The watch needs to be opened up and shorted out. With a pair of thweezers touch the AC & the - and this should solve your problem.
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches.
Instructions for resetting the time on a Klik or Crane & Viceroy watch.
With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B"
For setting the watch to GMT all hands need to point to 12 oclock exactly.
To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes.
Notes:
If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc.
If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery.
If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30.
if you want any other info my email is;
[email protected]
