I have purchased an LG LH-T3602ME and it is locked to region 4 how do i unlock it as the service person from lg asked me search online . I have a LG LH-T3602ME which is locked to Regional code 4. How do I unlock it to play all DVD's, particularly code 2?
Enter the following via the remote:
1. Power on,
2. Press "Pause" ||
3. Enter "314159"
4. Press "0" (for region free)
5. Press "Enter"
... the 0 replaces the previous region number in the second line.
6. Press "Enter"
7. Power off.
I better suggest you to get the codes from http://www.dvdunlocks4u.com/
It will tell you how to do and also give you a 100% working code..
But it will charge you $9
Goodluck,
please don't forget to rate me as fixya
Hi if you use ask.com and type in region codes for then lg dvd players this should give you a list of sites that give the codes that is if its possible to change yours as some you cant do nothing with.
If you come unstuck ill look for you but post back if you need me to do this as i cant do it for about 30min as just finishing work let me know ok
Is 4 your home code region i know 0 is all in main settings sumware they shoudl show rgion free ok if ot dvd sdont surport it ok usally have to a buy a region free player to play all disk from all ove rthe world ok thx agian nick helpap
I: For owners of LG HDD/DVD recorder: LH-RH7500W, that's the LG Home Theater System, with 80G harddisk. To get region free, 1. goto setup. 2. Move to the LOCK icon. 3. press number 0 button on remote 7 times (0000000). This will toggle Region Free or Region Lock.
1. Power on the player with no disk in the drive
2. Press "PAUSE" on the remote
3. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display)
4. Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.)
5. Press "PAUSE" on the remote
6. Power the player off and then back on
try these ok if not then your player not made to do this ok thx again nick mark me as fix ya
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select Ok when congratulation message appears
try all these ok
turned on the player, no disk inside.
- opened the disk tray
- pushed 3 times the 0 button on the remote
- pushed the pause button on the player
- pushed the 0 button on the remote
- closed the dvd tray
- turned the player off.
Press pause with no disc in the player.
Push keys 314159 (comment does this refer to PI = 3.14159?)
Player goes into multiregion test mode.
Select region 0 for multi region.
Press pause to exit.
Cycle the power off/on
these are the ways to do it ok
'all' LG dvd players to break coding follow these steps. it worked for me, i'm from australia, i was told it works for all LGs... step 1- POWER ON "NO DISC" appears on screen; step 2- press PAUSE, 3, 1, 4, 1, 5, 9; step 3- "CODE_ _" appears on screen; step 4- 0, PAUSE, then POWER OFF!!! that's it, good luck guys! hope it works
1. Turn Player on with no disc inside
2. Press pause on the remote control
3. Then key in 3 1 4 1 5 9
[CODE -- will then be displayed on the player display]
4. Key in desired Region number
[0 for Auto Multi Region, or manually select 1 to 6]
5. Then Press Pause again
6. Turn off player and wait 5 seconds, then back on aga
thx nick mark me as fix ya ok
u dont need that to pay 9 buicks just use this ok
this is 9 bucks of info right here should do it for u ok
also cool guy were suppose dto do this for her like i did not push her off him to a site to pay more ok buddie nexttime please dont do that
Nick, you are my hero!!! Just reading your comments helped me unlock my player! thank you thank you thank you!!!
Thanks, your suggested procedure worked, but for step 5 I needed to press ENTER rather than pause to keep/store the code change.
