SOURCE: U-LINE BCM95 NOT CYCLING
These units take a full cycle to get to the fill cycle, so you won't get ice on the first cyle unless you manually fill the tray when you first power it on. You may have some air in the water line and need to cycle a few times to fully bleed the air out. Also check the water inlet for debris in the filter screen using a small brass brush, then bleed out air -with water on- while tightening back hose connection avoiding need to bleed while cycling. Lyle
SOURCE: I have a u line
If compressor is running then unit has a sealed system issue- throw it away unless still under wty. If comp not running then probably bad relay on it. Only way to check is to replace relay. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
SOURCE: WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
SOURCE: ice maker stopped working
If you manually advance the ice and when the ejector blade reaches 10 oclock that when it calls for water. You should hear the valve come on. If not it could be a bad water valve. Part#2552A or you might want to doublecheck to see if your getting voltage there when the blade reaches 10 oclock. If no voltage then the water switch is bad.
SOURCE: Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
