Samsung DLP HL-P5663W 56" TV Logo
Posted on Jan 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung DLP R5067W just keeps shutting off intermittently. I bought this set in 05 and started having problems last year in late 08. I took the back off and dusted the parts and it has been working since. Now it is doing it again. How can I determine if it is the lamp that needs replacing?
Larry
Level 3:
  • Samsung Master 5,042 Answers
  • Posted on Jan 28, 2018
Larry
Samsung Master
Level 3:
Answers
5042
Questions
Helped
1240229
Points
18413
If you have a way to do it you can measure the current draw of the lamp, that will tell you if its close to failing
5 Related Answers
Anonymous
  • Posted on Jan 23, 2008
SOURCE: Samsung projection TV intermittent shut-down problem
I just called 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
My total was 167.08 for Fl. You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Anonymous
  • 206 Answers
  • Posted on Feb 13, 2008
SOURCE: Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Anonymous
  • 563 Answers
  • Posted on Jul 02, 2009
SOURCE: tv turns off after 5 sec.
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Anonymous
  • 4090 Answers
  • Posted on Aug 01, 2009
SOURCE: Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Anonymous
  • 5138 Answers
  • Posted on Sep 16, 2009
SOURCE: HLS5087W DLP Samsung Fan problem
Replace it if fan to Lamp stops running this will fix problem Call Mats 1-800-628-1118
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Not staying on
Most likely just needs a new Lamp. Should be able to pick one up cheap enough from eBay.
They are a consumable part and normally last only 2-3 years so not a big job or anything too serious.
I have a Samsung HL-R5067W. I have had this tv
the digital pcbs on these sets go bad and need to be replaced when they start showing these symtoms
I've had a Samsung HLR5064W for almost 5 years. Lately I've noticed when I turn the set on, the picture dims after about a minute. Is this a lamp issue??
Yes it's the lamp. I had the same issue in the middle of last year. I bought the whole bulb assembly for $220 Canadian. I'm confident that it was through Samsung USA.
I did find a site that said you could "save money" by buying the bulb only, but their price was the same for the bulb alone, as I paid for the whole assembly.
It took about 15 minutes to get the bad one out, and put the good one in.
Now I need to find out how to adjust the mirror angle...
Good luck
1helpful
2answers
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
1helpful
Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Samsung HL-R5067W "Powering Down"
the hlr series had a few problem with intermittent turning off. one was the lamp door cover switch, the other was the thermostat.. neither one is very costly and a good tech should be able to replace bothe parts at the same time..
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
