Dryers Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag neptune dryer has a very loud squeaking noise during the entire drying cycle
Curtis Sewell
Level 3:
  • Dryers Master 7,482 Answers
  • Posted on Jan 01, 2010
Curtis Sewell
Dryers Master
Level 3:
Answers
7482
Questions
Helped
1943132
Points
24946
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Screeching noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdgs
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
1helpful
Maytag neptune mdg4000aww squeaking during entire drying cycle. Could not find a repair manual on the net
Look here at part #24...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46720&diagram_id=660607#d660607
The notes for part #24 give you the other parts and help that you will need to stop the squeek. The drum rollers or the front bearing is the problem.
While you have it apart repalce it all.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
1helpful
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
heatman101
hgd76
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Top Dryers Experts
john h
