Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I sync the analog time with the digital time? (manual at home, I'm at work)
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290923
Points
7081
Press the button at 8 o'clock until "HS" is displayed.
press the button at 2 or 4 O'clock to advance or ****** the hands. Holding the button down will lead to rapid movement, pulsing the button will step it in small amounts.
4 Related Answers
Anonymous
  • Posted on Jul 18, 2009
SOURCE: Tissot t-touch analog time is out of sync with
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
A Miller
  • 8404 Answers
  • Posted on Nov 13, 2009
SOURCE: Problem Syncronizing the Analog & Digital
I believe yours is the same as mine ... the digital part supposedly ddrives the analog part. If you are off 15 minutes, it might be time to send your Citizen in for repair. I wouldn't trust just any Jewler with this.
Thanks for posting your quesiton at FixYa.com
Please vote
thanks
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 28, 2010
SOURCE: gettting the analog and didgital times to sync on my watch
Find Citizen manuals in my tips.
Anonymous
  • Posted on Jul 20, 2011
SOURCE: Have Rado 193. am
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
How do I set G-Shock analog time?
"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame).
Timepieces Watches Manuals CASIO
Cant get analog to sync with digital time. I live in SC and I try to set the time for 22:36 but then the analog set it to 12:36 am. :/
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
3answers
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 • Watches
Sync time in gshock GA110-1A
Simple straight forward instructions in youtube video below:
https://youtu.be/R84_g7Wrw4E
3helpful
2answers
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
1helpful
2answers
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
2helpful
Setting time day date in ESQ Aerodyne
3helpful
Analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
