Televison & Video Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When you turn on the TV it takes about 20 to fully turn on. sometimes we get pink lines on the screen.
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217467
Points
1225
CHECK POWER SUPPLY BOARD ...OR REPLACED
POWER BOARD NO:
Samsung BN44-00167A BOARD, POWER (VERISONS SX07,SX05,SS03,SQ01)
Samsung BN44-00165A BOARD, POWER (VERSIONS SX08,SX06,SS04,SQ02)
Abctay.com
Level 3:
Master:
  • Samsung Master 372 Answers
  • Posted on Mar 08, 2019
Abctay.com
Samsung Master
Level 3:
Master:
Answers
372
Questions
Helped
212257
Points
1385
SAMSUNG BN44-00167A SIP400B POWER SUPPLY works for SAMSUNG LNT4042HX/XAA,SAMSUNG LNT4053HX/XAA,SAMSUNG LNT4061FX/XAA,SAMSUNG LNT4065FX/XAA,SAMSUNG LNT4066FX/XAA
https://www.abctay.com/wholesale-samsung-bn4400167a-sip400b-power-supply-used-p-780.html
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Lines on screen
Try changing the input device to something you are sure works.Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
THE SCREEN IS BRIGHT PINK
Could be in the set but if using a cable or sat box unplug them and wait a while and plug back---I have seen a reboot of a box cure this issue.
2answers
The corners of the picture on my Sansui screen have turned pink
Hai,
That called ghosting or magnetic interference on CRT .
To eliminate ghosting, the easiest step is to keep the TV from equipment that has a large magnet. For example: speakers, electric motors and all that is magnetized.
Or you can also turn off the TV for 10-20 minutes to cool the PTC on the TV.
If it remains, try to move the location of the TV to other place.
i hope it will help you.
Ws55613.picture is wavy, sometimes it happens as soon as you turn the tv on and sometimes it takes hours. the wavy lines eventually become purple and pink. still able to see picture, but very annoying and...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
3answers
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
5helpful
5answers
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
