check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Frost in the rear of freezer possibly caused by door staying open. Door staying open possibly caused by frost buildup on ref door track. Start by making sure the teeth on the freezer track are clear of ice and frost. This should allow you to shut the freezer door. Next check the freezer seal. If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or for more help go to live chat.Thanks Len West
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door...If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well. Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door. To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication. It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!! PLEASE RATE THIS. THANX!!
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
