Refrigerators Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan motor on wine fridge
Uline wine refridgerator. Need to replace the fan motor.
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Jan 02, 2010
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114226
Points
558
Go to www.u-line.com and under customer service you will see service locator.
Avanti wc1500dss wine chiller not getting cold but does the opposite gets hot
https://manualsdump.com/en/manuals/avanti-wc1500dss/66172/12
The above has a troubleshooting matrix.
Power supply: Check if the wine fridge is receiving power from the mains supply. If it's not, there might be a major issue with the mains power or the PSU circuit board in the product that'll likely need replacing if it's faulty.
Condenser fan: The condenser fan is designed to cool the condenser and condenser coil within the Avanti wine cooler. If it doesn't function, the condenser and coil can overheat - causing the internal area of the wine fridge to heat up too. Take a look at the rear of the unit and make sure the condenser fan is spinning freely and not blocked (by dust / dirt) or making excessive noise due debris or a blockage.
Thermostat: If the Avanti wine fridge thermostat is working correctly, it's responsible for making the condenser, evaporator, fan, and compressor work - so it's super important! The thermostat also allows you to control and adjust the temperature of the wine cooler so if the reading on thermostat is inaccurate (or flat out wrong) the wine cooler temperature will likely be inaccurate too.
Why Is My Avanti Wine Fridge Not Cooling (And How To Fix It) - Expert Wine Storage
ULine U-2115WCS Wine Fridge flashing "ER" after temp.
Question edited for clarity.
Question moved to a better category..
The Thermistor has failed or is failing. It is the temperature sensor that is basically your electronic thermostat.
Troubleshooting Guide: U-Line Refrigerator Error Codes U-Line refrigerator troubleshooting begins with cracking the codes. Let's take a look at U-Line brand error codes.
Error Code ER
Diagnosis: Thermistor 1 is open
Explanation:
The U-Line refrigerator error code ER is alerting you to a failed thermistor. Thermistors are used for various temperature readings. These provide reliable temperature readings using a resistance which varies based on surrounding temperatures. If you have a U-Line wine cooler, for example, it will include ambient temperature surrounding the refrigerator unit.
If the thermistor 1 fails, the refrigerator will continue to operate on a preset 10 minutes on and 30 minutes off time interval.
Solution:
Use an accurate ohm meter to test the thermistor. If the thermistor is defective, have it replaced.
https://www.google.com/search?q=uline+u-2115wcs+thermistor
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
2helpful
Fridge fan motor is making a wining noise constantly when fridge is shut, seems continually cooling
if fan motor making noise its not turning fast enuff to get frige cold enuff to shut off replace it
4helpful
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Top Freezer working, Bottom Fridg not.
ice block has formed in the air exchange from the freezer to fridge. Turn off and thaw out, afterwards, check to see if the fan motor is running unobstructed. If problem persists, replace fan motor with new
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
