Haier BC112G Wine Cooler Logo
Posted on Jan 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wine cooler gets too cold (freezes)
Wine cooler doesn't set at the right temp. for wine it just keeps getting colder and colder even freezes???????????
  • 8 more comments
  • Anonymous Apr 05, 2008
    My 3 year old Vinotemp VT60 has just done the same thing. It was 25 degrees! I had over 40 bottles of $50+ wine in there. Not sure how long it was at that temp, but at least 3 days. Very frustrating.
  • Anonymous Jul 07, 2008
    my Haier wine cooler just keeps getting cooler and cooler , down to 32 F now so I have to keep unplugging it . Need a fix before it ruins my wines !
  • Anonymous Mar 17, 2014
    I just purchased this Summit SWC-520 wine cooler and went to plug it in and is reading S5 what does that mean and How do i fix it?
  • Anonymous Mar 24, 2014
    setting temp
    IT JUST STOPPED RUNNING
  • Anonymous Mar 26, 2014
    Not cooling
  • Anonymous Mar 28, 2014
    Frigidaire 38-bottle wine cooler error code
  • Anonymous Mar 29, 2014
    the wine cooler works, temperature never gets cold, used to leave it at 4deg. motor runs well, shelves are half full,
    any helpful hints, please
    upper level of wine cooler won't hold proper temperature
    koolatron product
Felizardo Erilla
Level 2:
  • Expert 241 Answers
  • Posted on Jan 21, 2008
Felizardo Erilla
Expert
Level 2:
Answers
241
Questions
0
Helped
312504
Points
619
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4162
Points
Always show E2 on display
I have a Everstar HDWC35 that chills the wine so cold that the corks pop out when the wine freezes even though the temperature is set at 58
The most likely cause is that you have a bad temperature sensor. Some wine coolers will display the set temperature, not actual temperature so although you set it for 58°, the temperature inside is much colder. If the temperature sensor is bad, then it's likely sending a signal to the control board that says it like 99° so the wine cooler is always trying to cool down to 58°. If you have an independent thermometer, put it in the wine cooler and see what it reads.
FYI, bad temperature sensor are pretty common in wine coolers. It's a design flaw that most manufacturers are just recently correcting.
Mar 03, 2019 • Furniture
2answers
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
3helpful
2answers
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
2helpful
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
1helpful
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
2answers
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
1helpful
Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
3helpful
4answers
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Top Haier Furniture Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Haier Furniture Expert? Answer questions, earn points and help others
