U-Line 75WC Wine Cooler Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Uline wine cooler 9 years old, model ULN-15VWC-00. Seems to be cooling ok but when i opened it tonight the inside back wall of the unit has major ice build up. I have turned it off and hope that this melts..Why is this happening? This is the second time I noticed that this has happened. this was not cheap unit. It was a custom mpdel.
Gil Shultz
Level 3:
  • Master 3,464 Answers
  • Posted on Nov 29, 2009
Gil Shultz
Master
Level 3:
Answers
3464
Questions
Helped
731148
Points
11104
The odds are your door gasket is leaking.
Good Luck,
Gilsh
ULine U-2115WCS Wine Fridge flashing "ER" after temp.
Question edited for clarity.
Question moved to a better category..
The Thermistor has failed or is failing. It is the temperature sensor that is basically your electronic thermostat.
Troubleshooting Guide: U-Line Refrigerator Error Codes U-Line refrigerator troubleshooting begins with cracking the codes. Let's take a look at U-Line brand error codes.
Error Code ER
Diagnosis: Thermistor 1 is open
Explanation:
The U-Line refrigerator error code ER is alerting you to a failed thermistor. Thermistors are used for various temperature readings. These provide reliable temperature readings using a resistance which varies based on surrounding temperatures. If you have a U-Line wine cooler, for example, it will include ambient temperature surrounding the refrigerator unit.
If the thermistor 1 fails, the refrigerator will continue to operate on a preset 10 minutes on and 30 minutes off time interval.
Solution:
Use an accurate ohm meter to test the thermistor. If the thermistor is defective, have it replaced.
https://www.google.com/search?q=uline+u-2115wcs+thermistor
1helpful
U-Line ULN-15WCSS-00 Built In Wine Storage Refrigerator. How to remove and replace wine racks in ULN-15WCSS-00 please.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
https://www.amazon.ca/s?k=U-Line+wine+fridge+shelf+support&i=tools&crid=6P110ETE4YHD&sprefix=u-line+wine+fridge+shelf+support%2Ctools%2C69&ref=nb_sb_noss
https://www.google.com/search?q=u-line+wine+fridge+shelf+supports
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 • Furniture
1helpful
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
2helpful
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
2helpful
2answers
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
4answers
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
Top U-Line Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
