Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
Posted on Nov 26, 2009
I am unable to print excel spreadsheet - no facility to remove grid lines and as a result it wants to print a small spreadsheet into 666 pages
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
796
Points
I can see the page in excel with data i want to print but when i want to see the print preview or print the page, i am unbale to access the page. some fixed pages crops up for print preview or on printing the page
Print Column Headings & Grid lines on a Spreadsheet
Dear Leoandpollyk
select the range on spreadsheet of which the grids to be printed.right click select format.on this window click boarder here select bothe coloumn and row lone then click ok. this will shows the range slected in darker grid also can prints.
thanks.
How to get lines on horizontal lines on the page.
you have to turn on the border. Highlight cells that you want to add the lines to, Right click on the highlighted cells, and select "Format Cells" Then choose the boarder tab. To only do horizontal lines, simply click on the top and bottom lines. This will turn the borders on, and then they will print.
3answers
How do you make lines appear on an excel sheet?
I'm not sure what Version you're using, so I'll assume after Excel 2010.
At the top of the page, under the Home tab and directly under the Font window, there is an icon which looks like a window frame (dotted all around except on the bottom edge).
In your spreadsheet you have to select the area you want to work on. You can select a single cell to add lines to or the whole spreadsheet. Click on the icon I described above and a menu box will pop down. There many choices which allow you to select lines on all sides of your work. I prefer the one at the bottom which says 'More Borders'. With that window you select the edges you want lines on, the thickness/type of the line, or put an outline.
I think that's enough for now and I hope that gets you started.
3answers
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Regards,
Shrey
UNABLE TO PRINT LANDSCAPE AFTER 1: OPEN SPREADSHEET FILE 2: GO TO PRINT 3: GO TO PROPERTIES 4: GO TO PAGE SET UP & CLICK LANDSCAPE 5: GO TO PRINT PREVIEW(DOES NOT SHOW OR PRINT LANDSCAPE)
You need to change the page layout within excel set it to lancscape.
for excel 2007
Look along the top ribbon and click on "Page Layout"
then select "orientation"
and change to "Landscape"
MY printer will not print Excel spreadsheets
I had this problem on my Vista pc but it was for all programs it would say its printing and nothing happened,what I did was leave the old one installed on the pc and created another and then deleted the old.But have you tried uninstalling excell and re-installing it to see if that changes anything, and when you reinstalled epson did you go to their site and download the updated firmware/software for the printer this could be another cause?!
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Printing excel attachments.
Try downloading the file and then print it
Unable to create chart in excel
Check the source data that it is using to create your chart (right-click choose SOURCE DATA). The result you're getting sounds as if it may not include all the data you want to chart. Generally should include at least two rows AND at least two columns.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
