Vizio VO22L 22 in. LCD TV Logo
Posted on Nov 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One channel has no sound but another tv works fine
Dave Naylor
Level 3:
  • Master 834 Answers
  • Posted on Nov 19, 2009
Dave Naylor
Master
Level 3:
Answers
834
Questions
Helped
223415
Points
2476
Your set is in the SAP mode go into the cutomer settings and locat the sound setting and turn it to stereo
  • michaejg Oct 20, 2010
    Thank You Dave!!
Don Johnson
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 03, 2020
Don Johnson
Contributor
Level 1:
Answers
Questions
0
Helped
7519
Points
Look under “Channels” then “digital auto” then select “English”.
Any other selection other than English produces no sound for only that channel. Everyone knows that right!
Anne Agnew
Level 1:
New Friend:
  • Posted on Mar 11, 2019
Anne Agnew
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7519
Points
Can't find any sap or Mrs either on remote I can see it is set to mono but can't see any way to change it to stereo.
1 Related Answer
Anonymous
  • 416 Answers
  • Posted on Mar 26, 2010
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
No sound some channels
HI
IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY
THANKS
M NASIR
Cant change channels with remote or side of tv - sound works fine . stuck on espn - no other channels work (i quess being stuck on espn is fine but this is an office tv for thr girls while they are eating...
Your TV is most likely locked to that station because it doesn't have any other channels programmed in.
In the menu for the TV, run a channel scan. This will take probably 30-45 minutes for most TVs and will program the available channels into the TV so that they become available.
Channel 2 (cbs) is fine. There is no sound. All other channels are fine. What is wrong and where can I take to have repaired. The TV is a 20" Norcent. I am in Summit,NJ, 07901
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
3helpful
2answers
Panasonic 32LX70, I have basic cable and the sound
I have the same issue. Its not the cable because all the other tv's are fine when tuned to those channels....Any luck?
1helpful
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
1helpful
2answers
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
