It's not a single button. Press MATH then 1 to select the ->Frac command.
There is no fraction button, but if you divide two integers (whole numbers) and want to keep the result as a fraction press [MATH][1:|=>Frac] [ENTER]. If the fraction can be reduced to its simplest form that is the result you will have.
27/48 [MATH][1:|=>Frac][ENTER] displays 9/16
Hope it helps.
Texas Instrument has released a major update to the TI84PLUS/SE. This
update numbered 2.53MP introduces Math Print that displays fractions as
one sees them in textbooks. Installing it will allow the user to
manipulate easily fractions (mixed numbers, improper fractions )
calculate logs in arbitrary bases, configure the calculator to convert
automatically fractions to decimals, etc. It is WORTH installing.
This bull s. H. I. T.
yes..thanks
Do you mean the ->Frac command to convert a decimal representation to a fraction? Press MATH then 1.
