Texas Instruments TI-84 Plus Calculator Logo
Posted on Nov 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TI 84 plus calculator refuses to graph more than one function
My TI 84 plus calculator refuses to graph more than one equation at a time in the window I have tried everything I know of to fix, it seems to be a common problem.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Nov 10, 2009
k24674
Level 3:
Answers
8093
Questions
0
Helped
4672886
Points
21595
Please, read the following, even if you already know some of its contents.
  1. Once you enter an equation, the corresponding equal sign is highlighted by default.
  2. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted.
  3. If one is not highlighted, move the cursor on it and press ENTER.
  4. If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER].
  5. Command PlotsOff echoes on main screen.
  6. Press [ENTER], screen displays Done.
  7. Restart the graphing procedure.
  8. If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
You should make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
I want to know how to graph equations on the TI-84 calculator
You must cast the functions in the so-called functional form y=ax+b. Isolate y for both functions, then open the Y= function editor and type in the second member (right member) of y=ax+b.
You can enter both functions and have them graphed on the same screen. In that case one will be on the Y1= line, the other on the second line.
Make sure that both = signs in the Y= editor are highlighted if you want both functions on the same graph.
How to use ti 84 plus calculator to graph linear equations
You have to use Y Editor to define functions on the both sides of the equation and then graph it. Finally option is F5: Intersection.
See captured images for equation 5x+10=-2x-7, y1=5x+10, y2=-2x-7 and x=-17/7
How do i graph an equation on a ti-84 plus silver edition calculator?
1. To graph a function, Press [Y=] to enter the function editor.
2. Type in a legitimate function.
3. Press ENTER to validate the function.
4. Press the GRAPH key to draw the graph.
5. Play with the window dimensions or use the ZOOM feature
to see more of the graph (or less).
Try your settings by drawing the function y= x
If you have problem with Invalid Dimension or other errors, turn the
Statistical Plots OFF.
To do so, press [SHIFT] [Y=] to open the Stat Plots.
Type in the number to the left of the Option PlotsOff. Then press ENTER.
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
When graphing and equation how to I put it plus or minus
You can't have a function return two results. You can graph it as two separate equations, one for the plus case and one for the minus case.
18helpful
My TI-84 calculator keeps saying "ERR:INVALID DIM" whenever I try to graph a function. I have used many different equations and tried to reset the scales and stuff in the "WINDOW" but it keeps saying the...
One of the statistical plots is turned ON and you must turn OFF all the STAT PLOTS.
To do so
  1. Press [2nd][Y=] to access the stat plot configuration.
  2. Select [4:PlotsOff]
  3. Command PlotsOff echoes on main calculator screen
  4. Press [ENTER] to execute it.
  5. Return to your [Y=] screen to define functions to graph.
  6. When finished entering functions press the [GRAPH] button.
Graphing an equation
Press the Y= key to invoke the Y= editor. Enter in your equation.
Press the WINDOW key to set the window parameters.
Press the GRAPH key to have the calculator graph the equation.
For more details and options, see the "Function Graphing" chapter in the Guidebook.
We are trying to graph a system of 2 equations on a TI-84 Plus but the calculator will allow only 1 of the equations to be graphed at a time i.e. only 1 of the = on the Y= screen can be highlighted at a...
Let us use the correct the terminology: You want to draw the graphics of two unrelated FUNCTIONS on the same calculator screen. That can be done but that does not make them a system of two equations.
Since it pains you to have to reset the calculator, I will try some solutions that may work within your constraints.
Turn STATSPLOTs OFF
[2nd][STATPLOTS][4:PlotsOff] [ENTER]
Clear all lists: Will erase contents of lists.
[2nd][MEM][4:ClrAllLists][ENTER]
Draw your graphs. If the ranges of the two functions do not overlapp they may not show on the screen with the SAME window dimensions.
If it works, fine. If it does not you will have to clear the RAM.
25helpful
2answers
MATH Graph Style Icons
go to apps menu, go to transform app. click uninstall and go to y= screnn and should be a slash on the left and you should be able to graph more than one equation.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
