Is it humming when you turn it on?could have a bad motor,something stuck in the blower wheel, pulley can be locked up or a roller is jammed,spin the drum by hand and see if the belt is moving,or if you can see if the blower wheel is moving,if they are the motor is bad,do you have power to dryer?
Have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
Sounds like the wheel at the back of drum where belt goes has come loose should be allan key screw/nut to tighten up again.
Hopefully that is the end of your worries.
Mick
