Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
REFRIGERATOR LEAKING WATER INSIDE THERE IS NO
REFRIGERATOR LEAKING WATER INSIDE THERE IS A SHEET OF ICE UNDER THE FLOOR OF THE TOP FREZZER ALSO NO ICEMAKER WHAT'S THE PROBLEM.AND HOW CAN I FIX THIS .
  • Anonymous May 11, 2010
    Good day,
    You mean it has no ice maker, or the the ice maker is not working ???
Anonymous
Level 3:
  • Whirlpool Master 1,606 Answers
  • Posted on Nov 10, 2009
Anonymous
Whirlpool Master
Level 3:
Answers
1606
Questions
Helped
569801
Points
5623
Remove the food and remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you
see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
403
Points
Where is the defrost drain? In the freezer section or the refig section. I have a freezer on top, frig on bottom.
Anonymous
Level 3:
  • Master 999 Answers
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
310997
Points
2740
The defrost drain has frozen with ice. You will have to remove all the ice and clear the drain. Be careful of the styrofoam ducts. make sure it is draining prperly and return it to normal operation.
Eric
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
2helpful
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Water leaking inside refrig. and then freezing in lower bins
your drain tube is blocked with a ice dam and there is ice under the freezer floor. Removing the rear panel and floor will give you access to removing the ice and clearing the drain.
Eric
Occasionally the ice cube maker overfills causing the water to fall to the frezzer floor and leaking onto the ground, any suggestions on how to fix this?
Are you sure its the icemaker overflowing? if it is, you will have icycles on all the shelves and the food leading down to the floor of freezer. If you have NO icycles between bucket and floor, you have a clogged defrost drain problem.
If you do have icycles between bucket and floor, you will also have a big block of ice in your ice bucket. without personal inspection, i would advise replacing both the ice maker and the water valve(s)
3helpful
Looks like water dripping from frezzer, but there isn't an ice maker hooked up in the freezer. top refridge shelf covered with water and ice
you have a blocked drain.i use a steamer to clear the drain,they cost around 50 bucks,take off the back wall.melt out ice with hair dryer,crack out as much ice that you can with plyers or hammer,gently hit it and it will crack out if the floor is a sheet of ice and a putty knife comes in handy,when you melt out and remove ice stick the tip of steamer in drain and clean the drain out,hit it for 10 seconds then stop wait a minute and hit it again,you don't want to damage the drain line it's plastic so take your time,pour hot water down drain to make sure it's clear you might have to use hair dryer and heat up the inside of ceiling in the fridge section in the middle of back wall and ceiling where the drain is, the air ducts are there also,whenwater stops dripping you'll know you melted all the ice,good luck
11helpful
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
1helpful
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
