SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't reset V-Chip and I don't have my owners manual, can I download one.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Nov 03, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368604
Points
33650
How to reset the clock in Nissan rougue
That info is in the owners manual, if you don't have one go here and see if you can download one. If none available then try eBay for a used manual
I changed oil and message is still there
You must reset the oil change due message, refer to your owners manual for instructions on how to do this. If you don't have the owners manual you can download one free here
How to reset my keypad on my 2002 navigater
Follow the instructions in your owners manual, but you must have the original code, if you don't the code is on the keyless entry module. If you do not have an owners manual you can download one HERE.
1helpful
1998 nissan sentra secuirty lite on will not start fule pump not pumping
Look in your owner's manual if you still have it. There is a fuse for the security. Check it and replace if necesary. If fuse is good, you can try resetting it by disconnecting your battery then reconnecting it after about 10 min. this should reset your computer. Be sure you are using the original key as there is a chip in it and matches up with the security feature. if you don't have the original key you will need to disable the security feature. You will probably need to call a dealership to do that.
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
2helpful
Where does the wood chips need to be placed in the smoker?? I don't see a chip pan.
If you don't have the wood chip tray, you're sitting dead in water, at this point. The wood chip tray goes above the burner, below the water pan. If this is a brand new, just purchased smoker. Go back to where you purchased it or call the number in Owner's Manual for "Parts missing". If it's not brand new, you can purchase a smoker tray from Masterbuilt Customer Service 1.800.489.1581
Hope this helped you.
Exactly how does the charcol come into play not exactly sure where to place it.
Debbie, unless you listed the wrong model number for your Masterbuilt Electric Smoker ... Electric Smokers don't use charcoal at all. They use wood chips, that are placed on the wood chip tray, just above the burner. The smoldering wood chips generate the smoke.
In case you've misplaced your Owners Manual. Here's a link to it that you can download and print for future reference. http://www.masterbuilt.com/pdf/manuals/07092010%2020070910%20Manual.pdf
Hope this helps you to enjoy your smoker.
If someone put in a code for v chip as a joke, can you do anything to reset it back to factor setting-no one will own up and this isn't funny!!
Check back pages of the owners manual for the reset steps, which usually are seperate from the v-chip (parental control) section of the manual.
8helpful
2answers
V-chip reset
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up]. 2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
