Master
- Posted on Oct 24, 2009
Re: I'm getting water coming out of the seam on the left...
If the washer leaks all the time, check these:
- Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
- Water fill hoses: Check the water hoses from the
household plumbing. Tighten it or replace
it as necessary..
- Main
tub seal: It is located between the transmission and
the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears
at the underside of the outer tub, at or near the center. The seal is
difficult to replace and you probably should call a qualified appliance
repair technician.
- Pump: You can spot the leak when the tub is
full of water if the pump leaks. The pump has two or more black rubber or plastic hoses
attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
- Outer
tub: The outer tub can rust, split, or be
punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
If the washer leaks only during the fill cycle, check these:
- Air-gap
device: It is a small device found on most washers that
prevents the wash water from being siphoned into the household water
supply. It is located either mid-way along or at the end of the black
rubber hose that comes from the water-inlet valve. It is usually made of
translucent plastic. If one of the air-gap components deforms or
cracks, you have to replace it.
- The
tube: It is a rubber tube that runs between the water-inlet valve and
either the air-gap or the inlet spout. If it cracks or breaks, it can
cause a leak.
- Inlet
spout: It is a plastic spout found on most washers near the top of the main
clothes tub that directs the water into the tub. If the spout cracks or
breaks free of its mounting, it can cause a leak.
