Whirlpool Duet Mdl GHW9150PWO Washer stops during various cycles flashes F02 or 5ud.
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
i have changed out the motor control, pump and cleaned the lines. the washer going throught the cycles until the spin cyle it gives me a F02 code
The control panel is showing a F02 error , whemn I reset it the cancel button will turn the unit on?
I have changed out everthing for the F02 code , what will the pressure switch do for me?
My unit will not responed to correct cycles. if I push cancel and hit cancel again it restarts
whirlpool washer error 5ud
not sure what this is
