U-Line Icemaker Logo
Anonymous Posted on Oct 08, 2009
Icemaker not making ice
Icemaker unit ULN-B195BTP-03 Unit has delivery of water thermostat is turned all the way to cold and temp is 35 degrees and not making ice
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114282
Points
558
Sounds like a sealed system problem.
WHIRLPOOL FRENCHDOOR NOT MAKING ICE
Most important thing to do is check for the internal temperature of the freezer section. The ice makers themselves have a thermostat that only turns on the ice maker when the temp is 10 degrees or less. If the freezer is not cold enough the ice maker will never turn on to cycle and make cubes.
Ice makers usually have hidden controls behind the front cover so you can manually start the unit and put it thru its paces. If your temps are below 10 degrees it should be working - if not maybe the thermostat that turns the ice maker on is defective or perhaps the cam motor that cycles the unit thru its various operations.
No water to icemaker!
i see no make and model # for your unit for i would check the internet for service manual, if the unit works when you power the solenoid manually than there is a censor or driver output transistor to the solenoid is defective and you will require a manual to service this problem, this problem location is on the control board or censor input to the board
The evaporator coil inside the unit ices up and causes the condensation drain to be blocked. Condensation then backs up and drips inside the unit and on my product. I have check the drain line and it is...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
I vacuum the unit condenser about two weeks ago. Last night I noticed there is a constant humming noise and the freezer will not reach its preset temperature of zero degrees, ranging from 14 degrees to 8...
The cold control is the knob in the ref that turns it on and off and has numbers on it.
The cold control probably the culprit
If this doesn't work Do this
Also this might be a common Defrost problem, Ice
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
I have two door refrigerator no frost but the unit could not make ice it has lesser cold output may i know whats the problem on this?
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Motor burnt out model uln-b195btp-11 looking for spare part
Here is the information you requested. To order, click on the add to cart button. results.gif Success, we found the genuine replacement part! Part Type Fan Motor-Refrigerator image-not-available.gif Description
FAN MOTOR FOR REFRIGERATOR
Our Part Number
Use this number to order online. Receive additional discount and free shipping
Z15-ULN-B195BTP-11-509
Price $161.01 Available Yes-In Stock Additional info FAN MOTOR FOR REFRIGERATOR
FREQUENTLY ASKED QUESTIONS-CLICK HERE
http://www.expertappliance.com/partfinder-sz.php
Hope this is the right one for you.
1helpful
My uline BCM45A ice maker is cold but does not make ice
This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
2helpful
2answers
I have a u-line ULN-WH95TP-03 THAT WILL FREEZE ICE BUT WILL NOT HARVEST THE ICE. I HAVE MOVED THE THERMOSTAT AS WARM AS IT WILL GO AND IT STILL WILL NOT HARVEST. IF I MANUALLY MOVE THE TIMER JUST A LITTLE...
Your thermostat is what advances your icemaker. You have 3 wires. When it calls for freeze then yellow(2) and blue/black(3) is closed. When that is satisfied the compressor and fan cycles off then the yellow(2) and red(1) is closed. This calls for the icemaker to advance. Red goes to icemaker, yellow is common, and blu/black is for the fan and compressor.
Hope this helps you. I would replace the thermostat
U line BI 95 icemaker is making but not ejecting made Ice
First thing to do is find the temp in the bucket. Should be between 10-15 degrees. If its colder then try turning the thermostat to a warmer setting. If its warmer than this then the unit is not getting cold enough. Look at the cendenser to make sure that its clean. If thats good you might have to check the thermostat. (if its 10-15 deg) Check the wiring. red goes on terminal1 yellow on 2 and blue /black on 3. The control might not be switching to harvest position. Wait until you hear the compressor and fan shut down then look at the icemaker. If not advancing then replace the thermostat.
Top U-Line Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
