Just wondering if you know of any fixes for danby countertop dishwasher leaking from bottom - only close to end of washing cycle - close to and during draining cycle.
Very important only use half teaspoon of soap. To much soap can cause it to leak. Also only use dishwasher soap.
I would think the drain hose from the unit is leaking from the description you give.let me know
how about the water line going to the fill solenoid valve?
sorry so late to reply but its the water line that connects to the unit then youll see the valve.
you will have to gain access to the water line pipe/hose going into the unit then you will see the drain hose.if the dishwasher doesnt leak until the end of the cycle it has to be the drain hose---i could be wrong.let me know.
im glad you found your problem.could you rate me as helpful.thanks,in the future if you need assistance let us know!
Thank you for your idea. Unfortunately this is not the problem. Both hoses - draining and filling are located at the back of dishwasher - and both are bone dry.
Not sure - how do I check this???
Thank you again for your attempts to help me. I have no idea where all of this is unfortunately. The water line simply connects to the connector and from there it is all sealed up. I guess I would have to take it all apart to find the valve???
Thank you all for all your help. I ended up getting a second counter top dishwasher that also ended up not working so well. I decided to try to make one working one out of the two. I opened them both up this weekend and found the leak issue to be the easiest to solve. It turns out that the tub ventilation outlet was broken and leaking. Such a simple thing and yet such a big mess when it leaked. I am now happily with a dishwasher that works very well. Again thank you.
Although indirectly, you did help me fix the machine by giving me ideas of what to look for the leaks. That led me to opening the dishwasher up and finding the leak that I wouldn't have found otherwise.
Thank you. Great service you have here as well. I will definitely check back when I have other problems and also if I find any solutions to other problems others may have. Thanks.
