U-Line 75WC Wine Cooler Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the metal racks in the u line 75wc refrigerator. They rusted in the back.
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Oct 08, 2009
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114291
Points
558
To order the racks you will need to order from a parts distributor. To find one in your location just visit U-line. www.u-line.com and under customer service you will see parts locator.
1helpful
U-Line ULN-15WCSS-00 Built In Wine Storage Refrigerator. How to remove and replace wine racks in ULN-15WCSS-00 please.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
https://www.amazon.ca/s?k=U-Line+wine+fridge+shelf+support&i=tools&crid=6P110ETE4YHD&sprefix=u-line+wine+fridge+shelf+support%2Ctools%2C69&ref=nb_sb_noss
https://www.google.com/search?q=u-line+wine+fridge+shelf+supports
1helpful
I have a U-line model 75WC. Want to change out wine racks with glass or wire shelves to change it to a beverage fridge. Any ideas on parts? Can I buy shelves for another unit to make this change?
glass shelves you can get cut from a glass suppler or window shop
if you have the measurements you may get wire shelving from a fridge service agent spares or cut wire fencing to size and have the parts powder coated to prevent rust
even aluminum security doors cut to size may do the trick
Aug 09, 2018 • Furniture
Power steering line rusted through going to rack n pinion
I'm showing a pressure hose available from most auto parts stores.
It has a metal tube on each end with a metal pipe between two rubber hose sections.
It depends on if the car has ac or not, and if it is a manual or automatic trans.
1helpful
Wine racks have rusted from moisture coming from back panel--don't know why there is moisture, or if the racks are replaceable
If the racks are removable, you can paint them with appliance epoxy paint sold
in spray cans by Rustoleum. It works well. I use it for refrigerator shelves at work.
Just be sure to wire brush or sand the racks before painting and allow sufficient
time to dry.
1helpful
2answers
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
1helpful
I need to replace the door gasket on a U-Line 75WC wine cooler.
Most of the time they send instructions with the new gasket./
2answers
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
2answers
Looking for 2 wine racks and the plastic retainers for same?
If you visit U-line at www.u-line.com and under customer service you will see parts locator. You should find a distributor to help you with that.
10helpful
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
1helpful
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Top U-Line Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
