Ricoh Aficio 1035 Copier Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ricoh Aficio 1045 error message SC726 - Ricoh Aficio 1035 Copier
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Sep 26, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
0
Helped
215193
Points
1334
Your top tray is out of position. you need to turn the machine off/on and watch the top tray. if ti cycles too high you will get the code back. you will need a tech to remove the tray reset timming and reinstall the tray.
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Sep 24, 2009
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150166
Points
26471
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
What does 'SC726 Problem with finisher' mean on a ricoh aficio 2022
sc726 is a finisher lift motor error. The lift motor could be bad, or the sensor that detects where the motor is might be bad. It could also be an overload problem, if something is in the way preventing the shift tray from lifting.
1helpful
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
9helpful
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
2answers
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
1helpful
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
AFICIO450 SC7260-00
Finisher shift/lift motor error. Could be caused be the tray or belt not being in the home position, a sensor, or a cable issue in the finisher section of the copier.
2helpful
5answers
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
