Unplug external USB devices and wait for sometime,now reset our machine and access in safe mode, run Reginout Scan.
Go to device manager if u see a yellow exclamation on the finger print adapter follow the code
Device Manager Codes: Information on how to repair the faults below is listed in our forums
Error Code 1 This device is not configured correctly (Code 1)
Error
Code 2 Windows could not load the driver for this device because the
computer is reporting two <type> bus types (Code 2)
Error Code 3 The driver for this device may be bad, or your system may be running low on memory or other resources (Code 3)
Error Code 4 This device is not working properly because one of its drivers may be bad, or your registry may be bad (Code 4)
Error Code 5 The driver for this device requested a resource that Windows does not know how to handle (Code 5)
Error Code 6 Another device is using the resources this device needs (Code 6)
Error Code 7 The drivers for this device need to be reinstalled (Code 7)
Error
Code 8 This device is not working properly because Windows cannot load
the file <name> that loads the drivers for the device (Code 8)
Error
Code 9 This device is not working properly because the BIOS in your
computer is reporting the resources for the device incorrectly (Code 9)
Error Code 10 This device is either not present, not working properly, or does not have all the drivers installed (Code 10)
Error
Code 11 Windows stopped responding while attempting to start this
device, and therefore will never attempt to start this device again
(Code 11)
Error Code 12 This device cannot find any free resources to use (Code 12)
Error Code 13 This device is either not present, not working properly, or does not have all the drivers installed (Code 13)
Error Code 14 This device cannot work properly until you restart your computer (Code 14)
Error Code 15 This device is causing a resource conflict (Code 15)
Error Code 16 Windows could not identify all the resources this device uses (Code 16)
Error
Code 17 The driver information file <name> is telling this child
device to use a resource that the parent device does not have or
recognize (Code 17)
Error Code 18 The drivers for this device need to be reinstalled (Code 18)
Error Code 19 Your registry may be bad (Code 19)
Error Code 20 Windows could not load one of the drivers for this device (Code 20)
Error Code 21 Windows is removing this device (Code 21)
Error Code 22 This device is disabled This device is not started. (Code 22)
Error Code 23 This display adapter is functioning correctly This device is not started. (Code 23)
Error Code 24 This device is either not present, not working properly, or does not have all the drivers installed (Code 24)
Error Code 25 Windows is in the process of setting up this device (Code 25)
Error Code 26 Windows is in the process of setting up this device (Code 26)
Error Code 27 Windows cant specify the resources for this device (Code 27)
Error Code 28 The drivers for this device are not installed (Code 28)
Error Code 29 This device is disabled because the BIOS for the device did not give it any resources (Code 29)
Error
Code 30 This device is using an Interrupt Request IRQ resource that is
in use by another device and cannot be shared (Code 30)
Error Code 31 This device is not working properly because <device> is not working properly (Code 31)
Error
Code 32 Windows cannot install the drivers for this device because it
cannot access the drive or network location that has the setup files on
it (Code 32)
Error Code 33 This device isn't responding to its driver (Code 33)
Error Code 34 Windows cannot determine the settings for this device (Code 34)
Error
Code 35 Your computer's system firmware does not include enough
information to properly configure and use this device (Code 35)
Error Code 36 This device is requesting a PCI interrupt but is configured for an ISA interrupt (Code 36)
Error Code 37 Windows cannot initialize the device driver for this hardware (Code 37)
Error
Code 38 Windows cannot load the device driver for this hardware because
a previous instance of the device driver is still in memory (Code 38)
Error Code 39 Windows cannot load the device driver for this hardware The driver may be corrupted or missing (Code 39)
Error
Code 40 Windows cannot access this hardware because its service key
information in the registry is missing or recorded incorrectly (Code 40)
Error Code 41 Windows successfully loaded the device driver for this hardware but cannot find the hardware device (Code 41)
Error
Code 42 Windows cannot load the device driver for this hardware because
there is a duplicate device already running in the system (Code 42)
Error Code 43 Windows has stopped this device because it has reported problems (Code 43)
Error Code 44 An application or service has shut down this hardware device (Code 44)
Error Code 45 Currently, this hardware device is not connected to the computer (Code 45)
Error
Code 46 Windows cannot gain access to this hardware device because the
operating system is in the process of shutting down (Code 46)
Error
Code 47 Windows cannot use this hardware device because it has been
prepared for "safe removal", but it has not been removed from the
computer (Code 47)
Error Code 48 The software for this device has
been blocked from starting because it is known to have problems with
Windows (Code 48)
Error Code 49 Windows cannot start new hardware
devices because the system hive is too large exceeds the Registry Size
Limit) (Code 49)
