Toro Lawn Mower With Toro Power Tools Logo
Posted on Feb 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ihave a toro rideon 17.38HXL model number.71243 serial number.240000407.when stared it runs rough then comes good until you start to drive and sounds like its going to stall then when you engage the blades itdose the same.I have checked fuel spark. Could it be somthing to do with the govoner.
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Nov 02, 2018
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112479
Points
562
Carb is probably dirty. an out of adj governor will make it rev high.
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Jan 28, 2009
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Anonymous
  • 1902 Answers
  • Posted on Feb 19, 2009
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Anonymous
  • 10865 Answers
  • Posted on May 30, 2009
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Anonymous
  • Posted on Aug 02, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Anonymous
  • 17 Answers
  • Posted on Aug 11, 2009
SOURCE: Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Part number for drive belt for toro 200016
91-2258 but your model # is a 20016 and you also have a serial number break. with any TORO product you need the serial number as well. Also, partstree.com can help you next time
Aug 18, 2014 • Garden
1helpful
I need a parts and service manual for a toro groundmaster 72''. model #30788, where can i order one, or is there a phone #
You can download or order manuals from the toro site
You need the model and serial number
Obtain the model and serial number from the model and serial plate on your product
https://lookup3.toro.com/request/request.cfm
3answers
RE: 42'' zero turn Toro with Kohler 19 hp. Ever since I bought it new, it has used oil, I am very dissatisfied with it. Model 74360 Serial #270000001. The starter relay doesn't work correctly. It will not...
Toro is a great brand, but the Home depot models are for home use. IF it won't start correctly you should troubleshoot the problem as this is a built in safey system for your benefit. There is a switch on both parking breaks, A switch to detect you sitting in the seat. The PTO must be disengaged. Check each of these. If you have your manual you can view the schematic diagram, and test each switch. If not, you can download a manual from Toro web site. According to your model and serial number your deck would only have two blades. They also have what they call "blade stiffeners" . Your results from buying power equipment from a big box store is typical. If you need service, pay a little more, and buy from your local power equipment distributor.
Jul 12, 2010 • Toro Garden
1helpful
Want down to down load owners manual for Toro 7 inch trimmer model 51556
If you use this link:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Then type in your model and serial number, You can download your User's manual. Toro is pretty fussy about handing out manuals hence the model number AND serial number are required in their site.
Thanks for using FixYa,
Kelly
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
2helpful
Replacement of Belt to mower deck on a Toro 17.38 HXL with model #71243
Go to this website:
https://homeownersolutions.toro.com/portal/server.pt?open=512&objID=214&PageID=0&cached=true&mode=2&userID=19461
Type in 71243 in the search. You want to click on the red tab that says "manuals". Look for the english version, if that is your preference. Click on the red text and it will open up a .pdf with your operators manual. Think it was on page 33 that gave belt lace instructions.
1helpful
2answers
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Toro model 20017 PP drive problem
I went to www.toropartstore.com. I put in your model number and found they had 6 different models depending on the serial number. I went to buy OEM parts and went thru the menus to bring up your transmission #106-3956. Try this site.
HTH
Good Day.
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
