Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Screen displays random lines and numbers.
  • kunka5 Dec 11, 2009
    Tried Reset Ram it works for a few minutes and then same issue occurs. Is there anything else to try?
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Sep 20, 2009
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675587
Points
21596
Clear the screen. Reset RAM :[2nd][MEM][7:Reset][All ram] [2:Yes] Ram cleared is displayed. [Clear] the screen.
Hope it helps.
  • k24674 Dec 14, 2009
    Start by identifying your calculator and by listing the apps and third-party programs and games that are stored in it. Describe a bit more what you call "random" lines. They may have a pattern. If possible, take a screen capture of calculator via TIConnect software, save it in in jpeg or png format and paste it in your comment.
I have a Samsung LED TV Model # UN60H7150AFXZA-It has a thin black horazontal line about 1/3rd up on the screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Just replaced my vizio 4kUHD LED main digital board, but am still having horizontal lines causing screen distortion.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Random faint horizontal lines scrolling down screen
If you wish to get some details; visit the site linked here. Pull up older posts.
1helpful
Lines on my display screen too.
More than likely you will need to replace the LCD screen. When it got wet, it probably damaged the LCD screen. Usually it justs blows them completely out.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is extremely easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the 580i LCD display and links to buy the screen.
Sony Ericsson W580i LCD Screen Replacement
I hope that helps you out
Have a 42" flat screen; the picture goes blank after two minutes each time after turning it on.
Hello
I have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.I don't have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.
And my problem is also resolved and its working fine.
Assistance by phone seven days a week.
1800 555 741
Thnaks & Regards
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
