Cameras Logo
K
Kathleen Sheehan Posted on Oct 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced batteries but Lo Batt continues to flash. Used energizers and installed correctly. How to stop flashing? Thx
Not Me
Level 3:
  • Cameras Master 3,158 Answers
  • Posted on Oct 19, 2019
Not Me
Cameras Master
Level 3:
Answers
3158
Questions
0
Helped
163814
Points
31816
What model camera is it? Can you go to the manufacturers website and look up the manual for it? Look in the manual for a Reset of the camera
Also check and clean the terminals inside the battery compartment
Try a different set of batteries just in case one of these is actually dead.
5 Related Answers
Walter H Boehm
  • 998 Answers
  • Posted on Jan 19, 2009
SOURCE: Inspiron 1200 battery light continually flashing orange
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 24, 2009
SOURCE: bAtt flashing on digital screen although I only
Yes, the flashing battery icon tells you it's time to change the battery.
Despite of that the watches are fitted with brand new batteries when they are leaving manufacturer, there can be a significant period of time till they reach their new owners and the watch battery can be flat (or allmost flat) at the selling point.
I suggest you visit sellers shop again a.s.a.p. and ask for the brand new battery to be fitted under the warranty.
Rate me, please.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: The time display won't stop flashing
Q: Why does the time on my clock flash?
A: A flashing display is an indication of low battery power. We recommend using fresh alkaline batteries. We do NOT recommend using rechargeable batteries or heavy duty batteries in any of our digital products. They are not designed for this type of use and may cause the unit to perform as a defective unit or not at all. They will also cause the display to flash 100% of the time.
Anonymous
  • Posted on Feb 17, 2010
SOURCE: i have a wii energizer flat panal 4x induction
The battery isn't connected to the Wii Mote (flashing red light)
http://ubermodder.com/energizer-wii-inductive-charger-teardown/
PrintDocta
  • 217 Answers
  • Posted on Mar 30, 2010
SOURCE: lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
My Energizer CHVCM3-UK has one side flashing green and the other solid green
https://www.youtube.com/watch?v=RaQwxvNrt4g
Green means batteries are correct inserted and they are charging, light goes off when batteries are full.
Blinking ill say is a problem of polarity or you used nonchargeable cells on that channel
How do I get my Flash to work?
First turn it on a indicator light will come on when energized
Make sure the correct batterys are installed light will come on faster then discarge I its broke from dropping it the flash wont work
I have a Cannon Rebel G EOS was purchased brand new for me quite some time ago. I used the camera a few times and then the battery symbol started flashing stating it needed batteries replaced. I...
Check the batteries on a meter,sounds like they are flat, you can get sold poor battery's as this is an older camera the shops can hold onto old stock, tell me more and i will look into it for you
5helpful
2answers
My beutler 800 said lo bat we replaced them and still reads bat lo
The other "solution" posted here is not a solution. According to this web site: http://www.espenergy.com/faq_honeywell_thermostat.htm
First, replace the batteries with a new set of AA alkaline batteries. If you insert the new batteries within 20 to 30 seconds of removing the old ones, you will not have to reprogram the thermostat. If the bAt Lo indication does not clear itself once new batteries are placed in the device install the batteries backward for 5 seconds, take them out, and reinstall correctly.
So I tried it... put the batteries in backwards. It completely reset the thermostat so I had to reprogram it (which was easy enough). One thing I did that the instructions did not specify. After I removed the batteries, I let it go completely blank before installing them backwards. Then I waited 5 seconds, pulled em out and put them back in correctly and eventually it started flashing indicating it needed to be programmed. HINT: Don't forget to set the current time!
After installing newly charged batter when I turn
How old is the batt.? I purchased a digital camera and after 2 months the batt. went bad. Have had it now 2 years and several batt.later.
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
2helpful
Ready light keeps flashing red. Replaced with a new battery from Kodak today but did not fix problem. No picture in LCD.
If the correct recommended batt supplied from KODAK didn't solve the problem Then a repair is recommended.
Info on batt:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
2helpful
3answers
No batteries work
turn flash to off in menu and it will at least work.
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
