Water keeps running and overflows in tray for 15- 20secs too long. Water supply will not stop doing it
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
http://www.appliancerepair.net/refrigerator-repair-1.html
SOURCE: Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
SOURCE: Water continues to drip from fill tube after the fill.
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
SOURCE: Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
SOURCE: water keeps going and overflows
Hi and welcome to FixYa. I am Kelly
You will have to open the top panel for steps below
Water level control is handled by the water level pressure switch inside the top panel. It is about 3.25 inches in diameter, has 3 wires connected to it and a hose that looks like a small vacuum line.
Check that vacuum looking line for any holes, kinks or disconnects.
You will need about 3 feet of the same knid of line available from any autoparts store for this test.
Remove the machine side hose and connect the 3 ft hose you just obtained. DO NOT drop the machine hose into the machine.
Place the timer on the wash cycle and start the cycle
Result = fill
Force air into the hose orally until you hear a click.
Result = fill stop agitation begin
If it does not pass this test then the pressure switch is bad.
If water never stops flowing the water inlet valve has debris internally and will probably have to be replaced.
Don't forget to reconnect the machine side hose to the pressure switch.
Thanks for using FixYa!
Kelly
Then remove the vacuum
there should be a shut off switch that might be broken or blocked in the open position when the water gets to the correct level this switch should stop the water flow. if it is broken or jammed the water will keep flowing. I hope this was useful.
