Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Good for you Barb, in the future be aware the for display adapters you can simply remove them and you would be prompted to re-install a driver for it at reboot. It will by default use a generic monitor driver so you just cancel out the install and then run the setup off the CD.
If you're talking about using an LG TV as a computer monitor, the generic display driver will suffice. I've never seen any noticeable improvement on display or features when Windows displays the monitor correctly or as a generic. If your resolution is too low and you couldn't increase it, the problem is likely your resolution setting or video card driver, not your monitor driver.
Look for a round metal threaded connector with a small hole in the middle. The end of the coax you will be connecting with couples over this threaded connector and screws on like a nut goes on a bolt.
Yes,the LCD inverter board is dead.Replaced the LCD inverter board will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
All monitors on laptops are listed as generic monitors and use a standard microsoft driver. If you have a driver already installed for this monitor, highlight the monitor and right click on it and check the driver details. You will probably see a microsoft signed driver. The graphics or display adapter is the driver that makes things happen on the lcd screen. That driver, the one for the display adapter is the one to keep updated.
Below is the link to HP support for the drivers for your laptop.
you are probably running generic drivers check display properties go to settings click advanced click adapter check specs if blank drivers generic check manufacturer site for prop drivers
