Can you recommend me some devices?
Many people complain that their television or electronic appliance got “burnt” as the voltage shot up suddenly. By saying “burnt” they obviously don’t mean that it was caught up in flames, but they refer to a very common phenomenon of an appliance becoming non-functional all of a sudden due to a drastic fluctuation in the incoming voltage. When the voltage increases abruptly to a very high value for a very short span of time, it is referred to as voltage surges.
is there any chance to prevent my PC from getting "burnt" because of voltage surges? I have already had my TV ruined once and dont want this situation to repeat. https://www.bestadvisor.com/best-uninter... might these devices be helpful by any chance?
SOURCE: Battery/Surge outlets not working...
Sounds like the UPS battery is bad, or the circuit break on it has gone. Is there a reset button on the UPS? Do you have the program that came with the UPS to check the battery status, those programs typically let you run a test on it also.
SOURCE: T2085 will not turn on
Obviously you have tried change of power cord, move the pc to another power outlet or test the one you are plugged into with a desk lamp or hair drier or whatever.. Also, some pc's have an on/off switch at the back of the box, especially if it's a tower pc, check that first.
Now, do you have access to another PC? Because it's easier to check this web site out, to see how to replace the power supply.. If not, post here for more help. Rgds,
http://www.hardwaresecrets.com/article/362
or
http://www.associatedcontent.com/video/2917/how_to_change_or_install_a_power_supply.html
Hope it helps, Rgds.
SOURCE: power supply board led green light blinks 3 times.
vscan is a voltage used to setup the picture for the panal. It goes to the y sus board. The problem is at the power supply or the y sus board. You can check these with a meter.
SOURCE: power supply shot when 3 weeks on same surge prot. all other eq. ok
YES !! IT CAN DAMAGED THE POWER SUPPLY , WHAT i SUGGEST IS TO USE AN APC BATTERY BACK UP & SURGE PROTECTION , SAME USE FOR COMPUTERS , FOR MORE INFORMATION GO TO:
http://www.apc.com , hope this helps , AJ
SOURCE: beepcode: single beep every 2 to 3 seconds continuous
Try taking out the ram and reinserting it also anything that is in the PCI Card slots.. other solutios is take and unplug each device and see if the boot up changes it will sometimes give a read code it might help eliminate the problem
Testimonial: "The information was very helpful. The problem was indeed with the RAM cards. One was making poor contact."
