SOURCE: replacing the mother board on my LG machine washing
disconnect power remove screw from back holding down top,slide top towards back. control panel is located on left rear of cabinet. remove 1 screw on back which hold panel in place. panel will side to inside to release from cabinet , pry open cover disconnect all connections (all connectors are color coded and are diffrent sizes)reverse process. hope this helps
SOURCE: Stinky grey goo in my Hotpoint WMA20 washing machine
you can only change the seal as this is a common fault with low tep washing
Follow these steps to replace your door
seal:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1 Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2 After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4 Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
