Replace shower head and see if the clog is located at the head.
Next suspect is the shower valve.
http://waterheatertimer.org/Low-water-pressure.html
Stop the drip by using a shower shut off valve ... it saves a bit of money each month and eliminate the aggravation
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#shut-off
SOURCE: shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
SOURCE: Very loww water pressure when taking a shower,
It could be debris in the cartridge at the tap itself. Whther 2 cartidges or 1 , it wouldn't be uncommon for those to clog up as well, and it really doesn't take much to cause a decrease in flow. Turn water off to tap(s) and remove handles, then cartridges in behind with proper socket or wrench and inspect for debris inside hole cartridge came out of, as well as the cartridge.
SOURCE: The shower is dripping water
Depending on the model of the valve, it can be as simple as replacing a cartridge, for example in the case of a Moen, or on a Delta replacing the seats and springs, and possibly the control ball. So what kind of valve is it and then I can give you a better idea?
SOURCE: Have a shower only no tub. replaced both the hot
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Testimonial: "I wasn't sure if that was the problem since I had just recently put a new shower head on, but it was the problem. Thank you for your help. "
SOURCE: my moen single lever pressure
The reason is cause the cartridge is installed upside down, I know this because I just did it and had the same problem, if you look very closely at the cartridge you will see an H and C they will be upside down
