SOURCE: Couln't initially set up my LUXOR combi TV/
You need to change the source to DTV and then press MENU ... go to the INSTALL tab and select First Time Installation
SOURCE: i have reset my neibours luxor lux-16-822-tvb
I'm sorry for the difficulties you're experiencing in getting the channels. I suggest that you perform auto programming to resolve the issue.
Thanks for understanding. Please let me know the result after performing auto-program.
SOURCE: I have a Luxor Lux-40-914-TVB and i got it for
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
SOURCE: Hey my mate has a luxor telly model lux 40 914
0000,0202,2244,3487. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
