Hello, Go here to login to manage your account and cancel or call your credit card, cust service and cancel automatic renewal for Mcafee. McAfee Total Protection
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
1. Switch to playback mode using the mode dial. Use the Left/Right buttons to locate and display the photo or movie that you want to protect. 2. Select the Protect setting from the Playback menu as described previously. 3. Use the Up/Down navigation buttons to select One to protect this picture/video, or select All to protect all pictures/videos in the internal memory or memory card. Then press the Right navigation button. 4. Use the function button to select Yes to lock the displayed picture/video or Unlock to unlock it, and use the Up/Down navigation buttons to select Back to return to the Playback menu. 5. A key icon will appear on the top of the screen to indicate that the picture/ video is protected. 6. Select reset to cancel protection for all files that have been placed in the protected mode. Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the
computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
Right click on the card and go to properties and uncheck the "Read Only" box.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
From Microsoft: "you may experience a problem when you visit some Web pages that are in different Internet Explorer security zones. When the problem occurs, you receive a message that resembles the following: Navigation to the webpage was canceled
This problem occurs if the navigation causes Protected Mode settings to change from On to Off. You can determine which Internet Explorer security zone a Web page is in by looking at the status bar at the bottom of the Internet Explorer 7 window.
This problem occurs because Internet Explorer 7 switches Protected Mode settings when certain Web pages are configured in the Trusted Sites area of the Security tab of the Internet Options dialog box. By default, Protected Mode is set to Off for Web sites that are configured in the Trusted Sites area"
Hi there. Check the card an make sure the write protect is not on, if it is, face the card towards you, look for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this .
Please post back if you need any additional advice.
