Outdoor Turbo Maxi Cool WBR115 small refrigerator
SOURCE: GE Profile CF24W-PL
Make sure the fan inside the freezer is running. If so, remove the cover from the back of inside of the freezer. If it is clogged with frost you have a defrost circuit problem. Most likely the defrost heater mounted at the bottom of the evaporator coil is burned out.
Post back with any questions and let me know what you find.
Thanks/Mike
SOURCE: my air conditioner won't turn on. When thermostat
sounds like your not getting a low voltage signal to the condenser, if your Air handler is in the attic check your secondary drain pan it might be off on the float switch, if your air handler is in a closet you need to check your float switch, it will have some wires coming out of it. Hope that helps you get started.
SOURCE: Ramsond Split system - R55GW - will not cool or heat
That would be the way to go even thought the cost is high. If not you run the risk of compressor failure and the metering device may be clogged. I know the price is what has you over a barrel but, the cost to you in the near future will be 3 times as much.
Sorry I could not cure the problem over the internet
Also check around there may be someone who could do the job slightly cheaper.
Dave
SOURCE: gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
