I would like information on hooking line voltage to a Bock 32E w/Carlin burner. I bought it lightly used from a tech a few years ago and stored it. However, I'm missing information and, or parts: There are three black and one white wire coming from the top conduit of the L4103A. One Blk splices to orange HOT under the cover. I didn't note the four wires when I bought it. I was expecting to just hook G-N-H as on my current heater. The other wires go to limit switches. I don't understand what to do with these as they also don't seem to correspond w/figure 5, page 8 of the PDF installation guide. Bock tech support states the L4103A is obsolete. Tech recommends BOC21365 kit probe, EZ-Temp, wiring harness. What are the component part #s of this kit? Do I really need this kit? Did the L4103A wiring go to a missing controller? Will a Carlin EZ-Temp 90000B work?
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
SOURCE: 2004 toyota corolla tach wire
you can also solder the wire to the tach wire, this way it won't come off and cause a malfunction
SOURCE: Break Light wiring diagram for 1998 dodge ram 1500
haynes repair manual has a brake switch diagrame
