Hi Arthur, more info would be helpful. Does this happen during the final rinse or during one of the initial rinses? Does the door lock at all and are there any error codes on the display? It has to be one of two things, the door lock itself or the control board. I recommend calling a local repair company to check it out. Hope that helps.
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
SOURCE: stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
