Video Cameras Logo
King Eris Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had a Sony HD mini dv camcorder back in 2007-08. I no longer have it so I purchased a canon on eBay. When I try and play the tapes I get incorrect tape specifications playback restricted. Now what
Looking for a work around or do I need to return canon camcorder
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Oct 16, 2019
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1652396
Points
20272
Nothing wrong with the Canon, but you cannot expect one piece of equipment to play tapes recorded a dozen years ago on equipment of a different make.
Your best bet will be to find someone to transfer the tapes to DVD for you.
Testimonial: "What do you mean. If I buy a 20 year old VCR I can play them in another VCR 20 years later. These are cassettes. Not digital Also. Who and where would I look to find someone to do this transfer. Thanks"
5 Related Answers
Anonymous
  • 73 Answers
  • Posted on Aug 02, 2007
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Anonymous
  • 19 Answers
  • Posted on Dec 21, 2007
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Anonymous
  • Posted on May 29, 2008
SOURCE: Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Anonymous
  • Posted on Jun 21, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Canon zr300 ejects tapes
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
DCR-HC26 will record but will not play
There are two solutions, one, buy a mini dv tape player. They are kind of expensive, but you will be able to get your information off your tapes. Second, buy a used, working mini dv camcorder on ebay and use it to get your information off your tapes. A five year old camcorder is not work fixing.
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
1helpful
The camcorder will not play tape it has an error How can I transfer my tapes to dvd's without using the camcorder itself?
You'll need a Mini DV player - I believe Canon or Sony has one. Then you can connect the player to a computer instead of using the camera.
Sony dv premium ME DVM60 Mini DV tape. How many times(hr) to use
Recommend contacting your local service provider directly or online here:
Contact Us
1helpful
No sound w/Sony recorded tapes played on Canon zr960
any recordings made from another digital video device may not meet the same specifications to play back correctly in any other brand model unfortunately. some work and some don't
Does this cam, play the mini dv tapes????
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
1helpful
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Canon xl2 playback
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
