Retail Supplies Logo
mala moodley Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mt jcm gold cash register is making a noise and showing E-P
Electroboy
Level 3:
  • Retail Supplies Master 1,888 Answers
  • Posted on Oct 19, 2019
Electroboy
Level 3:
Answers
1888
Questions
Helped
674428
Points
3733
Hi. It has a printer error. Make sure the paper isn't jammed. If it looks ok, take it to a dealer to be checked.
5 Related Answers
Anonymous
  • 1142 Answers
  • Posted on Jan 23, 2008
SOURCE: casio cash register not working
error code 1 on your cash register is due to Mode switch position changed before finalization
you can fix this error by Returning the mode switch to its original setting (does not beep) and finalize the operation
Anonymous
  • 298 Answers
  • Posted on Mar 25, 2008
SOURCE: ER-A330 SHARP CASH REGISTER PROGRAMMING MANUAL
The original English Manual has been discontinued. The only manual available is the German Version located here.
Anonymous
  • 737 Answers
  • Posted on Mar 10, 2009
SOURCE: Cash Register 2124ER making alarm noise when switching on
Wow. You must be the last person on earth with one of these. The printer rubbers have usually disintegrated on them by now.
We'll see what we can do for you.
First thing to do is to try turning the key to each position and press clear, then CASH in each position.
Anonymous
  • 737 Answers
  • Posted on May 08, 2009
SOURCE: casio tk 3200 cash register as stoped responding
Hi.
Try a flag clear:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Now turn key back REG mode and try it.
Anonymous
  • Posted on Aug 24, 2010
SOURCE: my sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
How can fix my cash register machine rest cause
Question makes no sense
Troubleshooting: Cash Drawer Does Not Open - Support Center
upserve.com https://help.upserve.com > article > Cash-drawer-does-...
... cash drawer can cause it to jam). 2. Check Receipt Printer Status & Cash Drawer Connection. Check that the Cash Drawer is connected to the Receipt Printer. The ...
Missing: rest ‎' Show results with: rest
Common troubleshooting tips for POS cash registers (2)
ComPOSxb https://www.compostech.net > common-troubleshootin...
Many fake crashes are caused by running programs that do not respond (for example, if you open or start too many programs at the same time, the program stops ...
Cash Register Troubleshooting Cash Register Problem
YouTube https://www.youtube.com > watch
0:59
#Cash register machine setting #cash machine main tax kese set krte ... Cash Register - Possible Causes Of E-10 Error Message. shopstuffltd ...
YouTube · Sharp Help · Dec 23, 2015
tip
How to REFUND, VOID, ERROR CORRECT on a cash register
Most cash registers are similar in operation when it comes to removing items from a sale (or after one).
ERROR CORRECT, or ERR CORR, or EC will remove the last product you entered during a sale. You simply press it straight after the item button to reverse that item back into stock.
VOID (infinity symbol on Sharp), or VD is used to remove any item from a sale e.g if you have entered four items in a sale, you can remove the first item by pressing VOID, then the item button.
REFUND, or RF, or RFND is your friend. It can be used to reverse any item at any time during, or after a sale. Just press REFUND then the item to reverse it back into stock. Then finish with a payment type e.g CASH if you are refunding cash back to the customer.
-------------------------------------------------------------------------------------------------------------------------- Need a cash register manual?
Sharp, Casio, JCM, Samsung, Sam4s, Olivetti, Royal, Omron, Sanyo, Towa, Geller, Uniwell, Javelin
Available here:
http://the-checkout-tech.com/cashregisters.php
on May 19, 2010 • Computers & Internet
1helpful
Samsung er-5240m electronic cash register key noises
If you are hearing key noises when using your Samsung ER-5240M electronic cash register, there could be a problem with the keypad or the register's internal hardware. Here are a few things you can try to fix the problem:
  1. Make sure that the keypad is clean and free of any dirt or debris. Sometimes key noises can be caused by foreign objects interfering with the keys' movement.
  2. Check the keypad's connection to the register to make sure it is secure. If the keypad is loose or not properly connected, it may cause key noises.
  3. Try resetting the register by unplugging it from the power source and then plugging it back in.
  4. If the problem persists, there may be an issue with the register's internal hardware. In this case, you may need to seek the assistance of a professional repair service.
2answers
Why is there a horrible grinding sound coming from the ink roller area?
#Tags how can i make my sharp xe a102 cash register work
159.203.8.28/.../how-can-i-make-my-sharp-xe-a102-cash-register-work
package of three sharp xe a107 cash register ink roller ... on in a few min. the car dies · Why is there grinding noise on driver's side as wheel is in motion? ... I have 05 honda pilot with a bad transmission what other type of transmission would fit ...
2answers
JCM Gold G355
please go to www. fitness.manualsonline.com or www. retrevo.com
God bless you
Need to key in my specials prices have used up all 24 preset ****
The TE-2000 should allow price over-ride as standard, so instead of just pressing the item button to ring up the preset price, type the price first on the numeric keys (NO DECIMAL POINT, so $5 = 500) then press the item button to sell it at the new price for that sale. --------------------------------------------------------------------------------------------------------
Casio, Elite, Javelin, JCM, Quorion, Royal, Samsung, Sam4s, Towa, Geller, Uniwell, Olivetti, Olympia, Omron, Sanyo, sharp, TEC cash register manuals available here: http://the-checkout-tech.com/cashregisters.php
Acom, Avery, Berkel, CAS, Digi, Ishida, TEC scale manuals available here: http://the-checkout-tech.com/scales.php
2answers
Casio cash register not working
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
