SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
SOURCE: cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
SOURCE: CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
SOURCE: aux input for MP3 player
I'am an M.B. tech- I do not beleive that this radio is mp3 compatable- iknow that the input you are refering to is used for ipod use. It very well could be that the head unit has to be programed(basically informed0 for an mp3- i would call the service dept. and ask to talk to ther best audio tech savay mechanic. Most likley the service writer wouldn.t know or give you false information because they do not stay on top of all the little tecnical changes. This fiber optic system has many programing features- most have to be done with as sds laptop(dealer software only) good luck
