When left off, water seems to trickle in so need to run the dryer to force the pump to remove water rising at bottom. I remove some basket/filter at bottom (from the inside) but am not seeing any valve or float part to investigate. There is some white cylindrical lock-ring that I am not sure if I can/should remove to get to the valve (or would that be accessed from underneath the dishwasher)... How do I fix?
SOURCE: no fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
SOURCE: Removing debris filters/cups at bottom of machine.
It does remove. I had a serious amount of lime build up that was making it difficult.
SOURCE: My dishwasher won't fill with water
if hot or both cold and hot fill try to switch the pipes
if not filling it may be a problem with program and or filter blocked
check also the pump
did you check the water is on as sometimes people forget to swith it on
if the motor has carbons as in the washing machine and if they are worn the water will not fill or better the motor is not going to turn and will not pump in water
as it is possible the pump may not work
this will make a sound like emptiness and with air in it
SOURCE: Miele Premier Dishwasher will not fill with water
click on this link directly to check out how fill valve looks
http://www.applianceaid.com/images/fillvalve.JPG
you will have to remove the access panels to reach the fill valve click on this link to get more instructions
http://www.applianceaid.com/dishaccess.html
This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
also click on this link directly to get all types of troubleshooting instructions
http://www.applianceaid.com/dish.html
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya.
