Radio Communications Logo
C
Carolyn Walter Posted on Oct 16, 2019
My MPOW Thor Bluetooth Headset is making a beeping sound
Ed Bee
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 16, 2019
Ed Bee
Contributor
Level 1:
Answers
Questions
0
Helped
2972
Points
Connect the headset to the charger as if you were charging it, but keep one side in your ear. Once connected to the charger, hold down the power button. It'll beep a few times and then stop. Disconnect from the charger. You can then turn the headset back on. This "procedure" clears the headset's memory,
1 Related Answer
Anonymous
  • 126 Answers
  • Posted on Aug 24, 2011
SOURCE: My plantronics savor m1100 bluetooth headset
Unfortunately, you will have to delete it and then pair it up again. It may be the only way to make the static go away.
Good luck from Headsets Direct - 800-914-7996.
Trouble pairing my mpow to a galaxy tab
MPOW headphones wont pair
To turn on the headset press and hold the power button for five seconds. The LED indicator will flash both blue and red letting you know the headphones are ready to be paired. Then head to the Bluetooth settings of your device of choice to pair the two together.
Scan for devices then press on your device they should now pair if password is asked for try 0000 or
1234
Bluetooth
When you connect a headset (after pairing you double-click the headset's icon and click the headset service) you will hear a beep on the headset itself. When you "answer" this by clicking the appropriate button then the connection is finally established - only then the sound is routed through Bluetooth.
It seems you are doing this already. But the problem is that this only affects programs that start using sound after the connection is established, or programs that don't keep the sound channel open. I am not sure that MSN does it. You could exit MSN, connect the headset (confirm the sounds are coming through it by using Windows Media Player for example), then start MSN again and see if it makes a difference.
4answers
I have nokia 6120 classic with BH-100 ear piece, how do you get the hands free ear piece to work
just go into the settings & there you will Accessory settings..
Thank you
May 21, 2008 • Cell Phones
1helpful
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
How To turn on the headset bloothoot nokia model bh212
Switch on or off
To switch on, press and hold the
multifunction key for about 2 seconds.
The headset beeps, and the green
indicator light is displayed. The
headset tries to connect to a paired
phone.
To switch off, press and hold the
multifunction key for about 5 seconds.
The headset beeps, and the red
indicator light is briefly displayed.
Pair the headset
1. Ensure that your phone is on and
the headset is off.
2. Press and hold the multifunction
key (for about 5 seconds) until the
green indicator light starts to flash
quickly.
3. Activate the Bluetooth feature on
the phone, and set it to search for
Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair
and connect the headset to your
phone. In some phones, you may
need to make the connection
separately after pairing.
If the pairing is successful, the
headset appears in the phone menu
where you can view the currently
paired Bluetooth devices.
When the headset is connected to
your phone and is ready for use, the
green indicator light flashes slowly
2helpful
My H15 bluetooth headset repeatedly beeps every second and I can't get it to stop. Everything else seems to be working fine. How do I stop the beeping?
First make sure it is fully charged then press both volume buttons simoultaneously until the blue light come on. May need to do it more than a couple of times to get it to work but the clicking sound does go away.
1helpful
I just need a pin number so i can pair my headset to my iphone
Step 1: Set the headset to be discoverable
Turn off the headset.
Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 • Cell Phones
47helpful
How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
3helpful
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
