Dryers Logo
Jo Townsend Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the error code f-22 on a kenmore HE 2 dryer dangerous???
Level 3:
  • Kenmore Master 6,688 Answers
  • Posted on Oct 16, 2019
Cindy  Wells
Kenmore Master
Level 3:
Answers
6688
Questions
0
Helped
3530588
Points
21745
The F-22 error indicates that the thermistor that detects the exhaust temperature has failed. (Sometimes the wiring between the thermistor and the control board will be faulty.) Sometimes the issue can be triggered by cold if the dryer is in an unconditioned space.
Unplug the dryer and access the wiring and thermistor. Check the wiring harness connections. Use a voltmeter to check the resistance across the thermistor. At normal room temperature, the resistance should be about 10,000 Ohms.
I hope this helps. Please add a comment with the model number (including the Kenmore prefix) if you need the parts diagram or other information about the dryer.
Kenmore Elite HE5 Steam dryer F30 code. How do I clear the F30 code.
Several possible fixes:
http://www.fixya.com/support/t1225051-kenmore_elite_he5_error_code_f30
Quoting:
"F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit.."
https://removeandreplace.com/2016/01/18/kenmore-elite-dryer-error-fault-codes/
Kenmore Elite Dryer Error Code = F30 Error Condition = Restricted Outlet Airflow
Check or Repair Needed = Check the lint screen filter and clean of any lint. Remove fabric softener buildup on the lint screen if necessary. Clear lint blockage restriction from the air vent exhaust system.
https://www.shopyourway.com/questions/1125417
Lint cleaning
http://www.fixya.com/support/t25862220-error_code_f30
What is error code F30?
Kenmore elite oasis st dryer - has power but won't run. Thermal fuse is NOT where I expected from videos I have watched.
Posted by Tom berwick on Sep 13, 2015
The F30 code is a false code. It does not mean anything. The dryer will work fine. When I worked for Whirlpool, this was a programming issue. I owned the same dryer. It displayed this code and engineers explained this to me. The dryer worked fine.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
5helpful
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
3helpful
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
